Hi,
About Me:
I am from India - Mumbai
I am planning to buy a new router for my home use..
My Setup/Details:
I will install this router in my living room (hall). I have 3 PCs in all in a 3000 SQ.FT. flat.
I also want to access internet from this router using my IPAD2 + Mobile. (want best wifi connectivity, long range preferred)
I have internet access via Cable LAN (2 MBPs line at present will upgrade to 8 MBPs next month) from http://www.pacenet-india.com/services.html
My Requirements:
I want to connect all my 3 PCs internally (networking) via this router.
I have a wired lan setup, so that this 3 PCs can talk to each other if they are connected to a router/switch from my living room. (I need fast file/transfer between this 3 PCs)
There are many IT geeks in my building (I want best security via this router)
None of my PCs has inbuilt WIFI (Can I get a feature in router someway which can help me connect all 3 PCs to each other wireless (without using wired cable which I am doing at present)
I want best security + best features + best future ready router (pricing is not an issue)
Please suggest me best option:
This is the best I could have found in my area/city, can you help me decide from this 4 routers.
http://www.flipkart.com/routers/com...2TCE9KQ84WE,RTRDF2T9HF7RNUXP,RTRD9TC4F3ZFWGMW
Rest of options available in my CITY are:
http://www.flipkart.com/computers/n...9f9-c6eb-4225-bf88-1570a3ee4f23&_pop=brdcrumb
http://www.homeshop18.com/wireless-...istView:false/sort:Price+High-to-Low/start:0/
http://www.primeabgb.com/index.php?...anufacturer_id=0&keyword=&keyword1=&keyword2=
http://www.bitfang.com/wireless-router/
If there are any other options you can suggest me depending upon my country. Please do.
Regards,
About Me:
My Setup/Details:
My Requirements:
Regards,
