I'm going with
Lian Li 65B case
Vista 64 Ultimate
Seagate 500 GB 32 mb
9800 GX2 (step up program)(Which brand do you like best)(Want 2560x1600 res)
Gateway XHD3000 30 in Monitor
I want either p35 ddr 2 mb or x48 ddr3 mb MB from Asus or Gigabyte
How much faster do you see CPU's going past 3.2 ghz on the 48 series ddr3 mb's
8 GB Ram DDR 2 or DDR3
CPU Any can always upgrade later
DVD RW with lightscribe (Do you think Lightscribe is worth it)
Soundcard best with Vista
PS 750 watt which brand and is one with cable management best idea or not
Thanks
Lian Li 65B case
Vista 64 Ultimate
Thanks
