Help me build my system
bitbum
I want to build a gaming PC that I will want to overclock and water cool. I have never overclocked an AMD system, so not too sure about what memory works
well, I'll leave that open. I was thinking about getting 2 GB because of memory intensive games. How will that effect overclocking? I chose the AMD 3700+ because of the larger cache. Does that make sense, or no.
I have put together some parts I think might go together well. Tell me what you think.
Case: CM Stacker STC-T01-UWK Black
Power Supply: Hiper Hiper Modular Type-R 580W HPU-4B580
Water Cooling: Swiftech H20-APEX
Hard Drive: Maxtor DiamondMax 10 300GB IDE Ultra ATA133
Optical Drive: Liteon 16X DVD Rom Drive
Motherboard: DFI LP NF4 UT SLI-DR Expert
Memory
CPU: AMD Athlon 64 3700+ Socket 939 2.2GHz CPU, L2 1024K, San Diego
Graphics Card: BFG Geforce 7800GTX
amd is easy to OC, but make sure you know what you're doing with that DFI board. I've heard there are ALOT of options in the bios that can be troublesome if you dont know what you are doing.
As far as the memory is concerned, just get some good stuff and try to run it without a divider. You should be able to get that san diego up to 2.6 easy.
