Help me build my next system
j0k3r
My wife is going to let me spend about $2k, so I need some advice. This is for gaming and it will be a dual-boot Vista/Ubuntu box. My questions are:
AMD or Intel?
Best chipset for each platform?
More RAM or more video card?
Crossfire or SLI?
Air or liquid cooling?
Best TV capture card(pref HD capable)?
I already have 1.5TB of SATA hard disks, DVD/Burner, and an 800w PSU so those don't need to be included in the price. ...just the case, proc, RAM, video card, mobo, nic(use onboard?), sound card(use onboard?), physics card(do these help much?), cooling system
If I can do this for all under $2k, my wife will thank you and so will I!
You should have absolutely no issues building under $2K, especially not since I assume that you also have a screen...
Go for an Intel CPU, E6600 or Q6600 if you want a quad core, either the proven P965 (for fsb overclocking) or P975 (can do crossfire), alternatively you can go for the newly released P35 chipset or nVidias i680 if you need SLi, stick to DDR2 memory, DDR3 is too expensive for what you get. Speaking of memory any decent 2GB kit will fine, chances are you won't need any more than that. For Graphicscard I'd go for either the 8800GTS/640MB or the 8800GTX if you need and the ThermalRight HR-03PLUS cooler if you are noise sensitive. Get a Heatsink for the CPU that mounts 120mm fans (Scythe and ThermalRight have the best here I think). I won't tell you what case to get, it's a matter of taste (I like my Antec P180b), Just go for something that uses 120mm fans exclusively, for more cooling at lower noiselevels.
If you look at the system in my sig and take the parts you need from there as a baseline (E6600+8800GTS) then it should not set you back more than $1100+case+Tax and shipping if even that. Add approx. $200 if you want that GTX instead and around $266 more if you want a Quad core.
1) AMD or Intel?
2) Best chipset for each platform?
3) More RAM or more video card?
4) Crossfire or SLI?
5) Air or liquid cooling?
6) Best TV capture card(pref HD capable)?
1) Intel outperforms AMD, overclocked or not.
2) Depends on what you need from the chipset... sli/crossfire, firewire, etc. P35 Express is probably the best for Intel, now. However, it doesn't do SLI/Crossfire. So, again, it dpeneds on what you need. For AMD, its probably the nF 680a SLI.
3) 4GB since ram is cheap, considering your budget. Vidcard depends on monitor size and games played at which settings.
4) For Ubuntu I'd sugget NVIDIA cards. SLI is more mature than Crossfire. Whether you need either one, again, depends on your monitor size.
5) Air is easier than Liquid. Scythe Ninja Plus Rev.B, Tuniq Tower 120, or Thermalright Ultra 120 are good air coolers.
6) DViCO FusionHDTV, IMO.
