Help me build my intel rig!
jdav
I recently sold my AMD x2 3800+ box so I could build another. I'm wanting to go with a core 2 duo on this build. I already have my case, PSU and optical drives. So, I need a CPU Motherboard, RAM, video card, and harddrive. I have $600 to spend on the parts so I'm asking the Hardforum community to pitch in and help find me the best bang for my buck. I will be purchasing through newegg and it would be awesome if you guys could link to the product pages. Thanks alot!
jdav
It's gonna be tight with that budget, but here goes nothing:
CPU: Conroe e6300: $190
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
Motherboard: Gigabyte 965P-DS3: $135
http://www.newegg.com/Product/Product.asp?Item=N82E16813128018
Hard Drive: Western Digital 250gb: $70
http://www.newegg.com/Product/Product.asp?Item=N82E16822144417
Memory: Corsair XMS 1gb DDR2 800: $123
http://www.newegg.com/Product/Product.asp?Item=N82E16820145566
Video Card: EVGA 7600GT: $110
http://www.newegg.com/Product/Product.asp?Item=N82E16814130062
Total: $628
I know it's a little over, if you're going to try and save a little more somewhere, I suspect the motherboard is the place to do it. This motherboard has a reputation for being a pretty good overclocker though, it's what I'm using right now. I think the extra $28 would be well worth it.
that looks pretty good, I may go with it, hopefully ordering tomorrow.
Well, I was just about to order, and the mobo is out of stock. Anyone have another suggestion because I need the computer tomorrow.
well its all ordered, thanks a lot joeshmo1985
MB GIGABYTE GA-965P-S3 P965 775 - Retail - $108.99
VGA EVGA 7600GT 256-P2-N615-TX R - Retail - $129.99
CPU INTEL|C2D E6300 1.86G 775 2M R - Retail - $190.00
MEM 512Mx2|CORSAIR TWIN2X1024A-6400 - Retail - $123.00
HD 250G|WD 7K 8M SATA2 WD2500JS % - OEM - $69.99
Subtotal: $621.97
What's this? Tax: $0.00
Shipping: $10.22
Rush Order Fee: $2.99
Heh, sorry about that, I knew the mobo was out of stock, but didn't know how soon you'd be ordering. Good setup, should overclock easy, enjoy!
