Help me build my computer plz
Poonpalace
Im am making a computer for about 2500 and I have these parts, what are your views on them? Should change anything/ get anything new or better for around the same price? Also I dont care about cool cases and I just want the one I have. Also should I get 939 or 940 pin? And if I get the 939 pin, which motherboard should I get that supports dual raid0 and the harddrives I selected? Help a noob plz
COOLER MASTER Praetorian Black ALUMINUM MID-TOWER CASE, Model "PAC-T01-EK" -RETAIL --
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only x 2
ASUS "SK8V" K8T800 Chipset Motherboard for AMD Socket 940 CPU -RETAIL -
AMD Athlon 64 FX-53, 1MB L2 Cache, 940-pins, 64-bit Processor - OEM -
Antec 550 Watt Power Supply With 2 Fans 5.25 Control Panel, Model "TRUE CONTROL 550W" -RETAIL --
OCZ Enhanced Latency Series Dual Channel Kit 184 Pin 1GB(512MBx2) ECC Registered DDR PC-3200 --
GeForce 6800 Ultra --
Thermalright Copper Heatsink for both Intel and AMD, Model "SLK948U" -RETAIL --
92mm Aluminum Case Fan from Xoxide.com
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL
Grand Total $2473
