Help me build a water cooling system!!
derrico
It was recently my birthday (16th) and ive been wanting to achieve better temps//overclocking abilities with my rig, ive never had any experience with water cooling and was wondering if maybe someone could put together a nice setup. I have 175$ to spend.
Current System Specs (also in sig)
E6300
Gigabyte-965P
Seagate320gb Harddrive
8800 GTS 640mb
Coolermaster centurion case
2G G'skill ram
stock intel HSF
Xclio500w PSU
I was going to post something tonight, I just got out of an exam ;)
175 is a fairly hard limit to reach, but I'm sure we can do something... Most will have to be purchased used from here on the forum if you want to include your GPU... Most new-priced GPU loops go for about 300$ . 250$ would be a MUCH easier target to meet... so I'd consider saving up, or going high-end aircooling instead.
A dangerden TDX CPU waterblock can be had for around 30$ on these forums... Make sure it's got the LGA 775 mounting.
A BIP 320 radiator can be had between 30-40$ used here too.
Masterkleer tubing and Yate loon fans are great products, and also the cheapest ones on the market... They're really great quality.
A D5 pump should set you back between 50-60$ used.
An EK 8800GTS waterblock is really expensive at about 100$.
if this is your first watercooling project.read some guides,look in the stickies lots of good info,if your gonna put it in your centurion case , gonna require some mods,i agree with
good luck !
