Help me build a system, budget: ~ $550
Hi, I havent been paying much attention to todays PC market and i would like to know what kind of system i could get today for around 550 bucks. So I am looking for a best bang for the buch and if possible future proof. My room mate wants a pc so i told him i will build it for him.
The computer will mainly be used to download music, movies, and occasionally some video conversions so i think a gig of ram is a necessity.
I dont know whether i should get an AMD or Intel, would it be better for me to go with some older sockets, so i can save money? Is it possible to build a decent system for that much?
thanks i appriciate your help
Ooh... ooh... system build suggestions are just about my favorite thing to do! :D
It is possible to build a decent computer for that much, provided he isn't a graphics maniac with his games.
Best "bang for the buck" sort of deal? Might I suggest...
Asus A85-X ATX Mobo:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131525
Athlon 64 3200+ Venice:
http://www.newegg.com/Product/Product.asp?Item=N82E16819103602
Sapphire ATI Radeon X1300PRO:
http://www.newegg.com/Product/Product.asp?Item=N82E16814102640
And a good HDD, DVD drive, value RAM and case/psu combo should top it off at about $550. You said he was doing some video conversion - ATI is traditionally known for superior image quality and video compression/conversion rates, so at least an ATI - and a X1000 series card (X1300, X1600, X1800, X1900) especially since they have hardware H.264 acceleration.
^^^^I like what you put together there...nice stuff, good for the price! I am now thinking about getting those components! :)
I would go for a motherboard with the nvidia 6150 northbridge for the onboard video. He does not really need to spend $175 on mobo+video card when he could spend $80 on a mobo with integrated video.
Here is an asus 6150 board
Sorry... but if he's doing video conversion, hardware-accelerated video is a must, which you aren't going to get with integrated... especially if he's going to do ANY HD video in the future.
lovelyx said:
For video conversion I would go with an intel processor.
Yeah, that's also a possibility, I just didn't want to totally seem like an intel fan here. :D And the difference between the two is probably neglible enough, especially considering future-proof Pentium mobos (support dual-core, EMT64, etc.) are a tad more expensive...
How much HD encoding is he expecting to do on a $550 Budget PC? Just throwing it out there...
The initial build looks good, but I'd go for the integrated vid and free up some jack for HDD space.
Don't know if you need a monitor, Keyboard, mouse, etc. Anyway:
AMD Athlon 64 3200+ (Venice) $160.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103535
ASUS A8N-VM CSM $62.00
http://www.newegg.com/Product/Product.asp?Item=N82E16813131570
Kingston Value RAM (1GB) $80.50
http://www.newegg.com/Product/Product.asp?Item=N82E16820141437
80GB HD ~$50.00
Lite-On DVD/CD RW Drive $40.99
http://www.newegg.com/Product/Product.asp?Item=N82E16827106009
Antec Solution Case (With PS) $58.99
http://www.newegg.com/Product/Product.asp?Item=N82E16811129150
Total: $452.48
I would stick with that motherboard and processor. You can always add-in a PCI-E graphics card later for gaming. You may want to spend the extra cash on a larger/faster hard drive. I would imagine someone could reccomend some cheaper RAM, I just happen to like Kingston.
HD encoding wouldn't be that hard to do on a $550 PC, trust me. Processors nowadays are more than able to handle file formats like H.264. Actually, anything above 1.5 GHz should do it. The main deal here is that the playback would be greatly improved with a stand-alone video card, as well as the conversion process faster. H.264 playback is a bajillion times better on my PC compared to my dad's with integrated video, and my card doesn't even have hardware H.264 acceleration.
Of course, this all depends on whether or not the thread starter's friend even messes with HD content yet. :D
BTW, in response to the poster above, I don't think a video card like a X1600 or 6800GS would be needed. He never said anything about gaming, and those are pretty much gaming cards...
