Help me build a storage computer...
CNV
I'm building a HTPC and was figuring out of a storage solution since I don't want to store everything on it. My friend suggested building a NAS. I want to start out with 4 750gb drives.. RAID 5. I will definitely expand it down the line as I need more space. So where do I start? I don't have any old components I can use so everything will have to be purchased new. Can you guys recommend me mobo/cpu, card, and case? The CM Stacker STC-01 looks good, but I don't think I need that much space...
Also, I have uTorrent on 24/7 because I am downloading and seeding 24/7. Can I run uTorrent on this rig and access it with another computer, or will I have to use a monitor, keyboard, etc to access it?
TIA.
