Help me build a pretty nice gaming system
Gob
My bidget is $1000 (CDN) Which is about $860 american.
I wanna play HL2, CS:S and BF:2 at 1280x1024 (1024x768 is acceptable for BF:S) with some high settings (full settings for the source games would be nice) as well as maybe some games that will come out in the nearish future
I'm not against buying an SLI (Or ATI Eqivilent) capable mobo but no SLI right now.
This is for ONLY the box (I already have a 50gig HDD, and would rather save money then buy a new one, and get a better performing system) so I don't need a monitor or mouse or anything, and I already have a copy of windows.
edit:Also, I don't want a "Super l337 case with lights and blu!!!!!!!!!!!!!!!1!!!!". A simple conservitive case is fine, It's under my desk anyways.
Also, no CD drives or sound cards or anything, I already have thos
Thanks
sac_tagg said:
So you need:
Case
PSU
mobo
RAM
video
HD (SATA)
fans/HSF/etc
Right?
No HD and no Fans (Ill use the stock ones)
Edit; Also, I don't OC, so I dont need "Super OCZ EXTRA SPEEEEEEEEEED" ram, el cheapo mexican made ram is fine.
Mexican made? Heh.
Anyway, check ncix for something along the lines of a Venice A64, Chaintech VNF4 Ultra, a gig of ram, a 6800GS, and a case of your choice, paired with a 24 pin PSU from someone like Antec or FSP. I'd provide links, but I'm about to leave,
WOw, I havnt been in this whole "Computer" scene for a while. I stop following for a few months, we have x1800xls, g800gs's, x800gts and all this other stuff
the 6800GS is pretty sexy looking, I just made this up:
AMD Athlon 64 3200+.............................$189
MSI K8N Neo4-F S.939 nF 4 ATX PCI-E16X..........$103
Kingmax PC3200 DDR400 1GB.......................$106
Antec Solution SLK3800B Mid tower...............$105
EVGA GeForce 6800 GS ...........................$269
Total with tax=888
(Canadian p[rices)
not that bad, a fair bit under my budget, and according to these reviews (Who were using the exact same specs):
http://www.techwarelabs.com/reviews/video/evga6800gs-pcie/index_6.shtml
It should be pretty sweet
Pretty good setup, but I would go with the Asus A8N-E or even the A8N SLI Premium if you later want to go SLI. I swear by Corsair, but others will say different. Looks good I think. :)
I don't have Canadian prices, but here are my recomendations:
ASUS A8N-SLI (it's $10 more than the A8N-E, and gets you the option of future SLI)
Athlon 64 3200+
Corsair Value Select
Geforce 6800GS or 7800GT (depending on how much cash you have)
Western Digital 250GB SATA HD (16MB Cache, SATA3.0)
Antec Truepower 480W (or Neo if you like modular)
I know you said you want the use your current hard drive, but if it is a 50GB one I'm guessing that it is an older 5400RPM drive with a couple KB of cache. Trust me, you want the SATA drive.
