First time poster here. I shall answer the required questions as best I can:
It's my work machine, so I will be doing a great deal of multi-tasking, including many Office documents, hi-res scanned in images, web pages, and possibly a video playing simultaneously.
I don't game
I will be doing some lightweight video editing and photoshopping
I need to have 4 monitors hooked up simultaneously
I would like it to boot up very fast, so an SSD drive for the OS is a must
About $1200
Wilmington, NC, USA
The case
Motherboard
CPU
RAM
Fan
PSU
GPU
SSD
HDD
DVD Burner
(So everything except displays, keyboard, and mouse)
no parts to reuse
6) Will you be overclocking?
No
4 monitors: 3 are 1920x1080, 1 is 16:10 1680x1050
2 monitors have VGA & DVI ports; 1 has VGA, DVI, & HDMI, 1 only has DisplayPort
I don't want to rule out the possibility of higher resolutions down the road
Before Christmas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3
SATA 6/Gb/s (I think?)
Onboard video (I think, since I have 4 displays?)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No. I would like Windows 10
I've never built a PC from scratch though I've installed RAM, drives, various PCI cards, and a PSU
The multi-monitor and quick boot time is key
I don't know whether I should get a core i5 or i7. Yes I will be doing the occasional video editing, as well as transcoding audio and video
Although someone recommended a RAID 1 setup, I don't think it's necessary. I'm very good with backing up regularly
Thanks!
I don't game
About $1200
Wilmington, NC, USA
The case
Motherboard
CPU
RAM
Fan
PSU
GPU
SSD
HDD
DVD Burner
no parts to reuse
No
Before Christmas
USB 3
Thanks!
