Help me build a new PC part 2
Rusky
Well for some reason my first topic was closed...
As I didn't get a chance to answer some of the questions posed to me I will answer them here.
This is going to be mainly a gaming PC, probably for ~4-5 hours a day.
I don't care whether it's Intel or AMD, I just want what will run the best :p.
I don't want to OC at all, I'm happy with what I buy hehe.
So far I'm going with:
AMD Athlon 64 X2 4400+ - $719
Geforce 7800GTX - $619
Maxtor DiamondMax 10 300GB - $200
OCZ EL Platinum Revision 2 1GB - $167.95
Total = $1,705
Left to spend = $795
If just gaming, you don't need dual core...overclocked Venice 3200 would be my first choice, but since you don't want to just get a higher rated one, check socket 754 too as you might be able to get a higher stock speed for less money than on 939.
Well gaming/college...
Why did you recommend a SLI board if he is only going with one 7800? I would recommend the NeoPower.
It happens :D
Stay away from the X2s, for what your doing you would be wasting your money hardcore...If you dont wanna overclock and want good stock speeds, just go with a S939 4000+, it operates at 2.4Ghz and if one day you decide that you wanna step into the OCing realm then you can OC that to about 2.7 or so.....But 2.4Ghz will do you fine for quite awhile...pair that bad boy with a 7800GTX and a nice DFI, MSI or ASUS board.....All those boards are good depending on what you want out of em, the DFI is a madman of OCing and stability. The MSI and ASUS boards are good for running stock and stable...
Just because I'm not gonna OC I don't see why I can't get the X2's. Money isn't that big of an issue, so I want what will run the best w/out OCing.
Also can you link me a good mobo if not the SLI one.
Thanks again
Nobody is telling you that you can/can't buy these things.
I think they're just trying to tell you that just because you don't have a price ceiling doesn't mean that you have to buy the most expensive equipment there is. Games aren't utilizing dual cores, yet, and neither are any of the programs you'll likely use for school.
Same with SLI. It's great, but you don't need it. It's not a bad idea to get an SLI board, though, just in case you might want to throw another graphics card in there in a year or so. Especially since, in a year, another 7800GTX will probably only be $200-$300.
Just chill with the money... you're spending as much on your processor and graphics card as I would on a whole computer.
Trust me, there are times when I wish my computer had a little more horsepower, but there's never been a time that I wouldn't rather have a few hundred bucks. College is a big cash drain, and it's not tuition that does it. It's books, food, hanging out, video games, food, books, food, and whatever your vices of choice are (drinking, drugs, gambling, or sex). And more books and food...
Well this is a graduation gift, so it's not going to be my money that is being spent.
I can see getting an x2 if doing more than gaming tho...If just gaming then i'd say get an fx-55 or 57 when it comes out as was mentioned. Dual cores do help on multitasking and will help in the future on games but not much atm. Can always get a good single core cpu and use the money saved to buy a vapochill to O/C it to an inch of it's life... :)
*rolleyes* you should know better to ask [H]forums for a non-OCing computer. Vapochill... honestly, if he doesn't even want to overclock on air why the hell would he get VAPOCHILL???
FX-57s are like $1000, so I doubt you can afford one.
Nice choices for your desired applications. I wouldn't reccomend anything more than Alex A suggested along with your own choices except maybe a second optical drive. They are like $40, so why not make it easier to burn stuff?
O yeah, maybe you should get some average timing 2x 1GB sticks. If you play BF2 or plan to play next-gen games, 2GB might be more future proof. Plus with an X2 what's the point of multitasking if you don't have the ram to support it?
Do you need a mouse, keyboard, speakers, or monitor?
Thats for the input!
You are correct that getting a vapo isn't worth is since I don't plan on OCing at all.
Things like mouse/keyboard/monitor/cd-rom I will salvage from my old PC. I've build PC's before so I'm not a total n00b :p , I just needed help figuring out the harder things like cpu/ram/mobo.
So you recommend the SLI mobo? because people say it's not a good one if I don't wanna OC...
Getting a vapo is always worth it, and if you're not going to OC the next step is to ship it to me. :D
http://www.newegg.com/Product/Product.asp?Item=N82E16819103529
San Diego 4000+ is what I'd choose for non-OCing. I don't think the FX-55 is worth almost double the price.
Isn't there that Dell deal where you can get a 7800gtx for ~$500? $619 for a graphics card is not something I'd personally spend.
Edit: http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2397&p=18
Looks to me like the 3800+ outgames the 4400+ x2
Edit2: It looks like you could cut down the price at least by going with http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80726-R&affiliate=pricegrabber
and the dell 7800gtx
It's under $500 actually...like 460ish I think. It should still be towards the top in Hotdeals. No clue if it's still good.
Also, for your hard drive you should skip the 300 GB and grab a couple 16MB cache Maxtor 250 GB Serial ATA drives for only a few dollars more.
Thanks for all the input, this is what I'm looking at right now:
Monitor - http://www.newegg.com/Product/Product.asp?Item=N82E16824001185 $354
Case - http://www.newegg.com/Product/Product.asp?Item=N82E16811162011 $53
Case - http://www.newegg.com/Product/Product.asp?Item=N82E16811162027 $49
CPU - http://www.newegg.com/Product/Product.asp?Item=N82E16819103529 $473.99
Motherboard - http://www.newegg.com/Product/Product.asp?Item=N82E16813131540 $184
Ram - http://www.newegg.com/Product/Product.asp?Item=N82E16820146890 $167.95
Video Card - http://www.newegg.com/Product/Product.asp?Item=N82E16814143036 $619
Hard Drive - http://www.newegg.com/Product/Product.asp?Item=N82E16822144359 $200
DVD-RW - http://www.newegg.com/Product/Product.asp?Item=N82E16827106988 $47.99
Mouse - http://www.newegg.com/Product/Product.asp?Item=N82E16826153104 $55
Some final things I would like to know:
Is the mobo/cpu/ram compatible (I've never built an AMD machine)?
Any recomendations on parts I should change?
This is going to be a college/gaming computer and I don't plan to OC at all, so don't suggest compenents that are only good if you OC them :D .
Once again thanks to all that helped.
Don't get that case/psu. You can't go with high end components like you are and then get a crappy psu. Get the Fortron Blue Storm and a case without a power supply - pick one out that you like. This one is a good case that looks like the one you picked out. That cpu/mobo/ram combo will work just fine.
Ok cool
I wasn't dead set on the case anyway, it was a random one I picked for now.
Other things that I am not set on getting are:
Monitor
Mouse
Does anyone know of a good LCD monitor?
How much are you willing to spend? If you are willing to spend alot then get a nice Dell.
Monitor: Samsung 19" 8ms LCD $354 (I have no experience with LCDs, so I'm not gonna reccomend anything. But, you might want a widescren or 1600x1200 monitor if you are gonna get a 7800GTX)
CPU: A64 X2 4200+ $527 (The 4000+ is a bad buy, and an X2 will be good for gaming longer)
Ram: Crucial 1GB pc3200 $106 x2 = $212 (much better buy than the OCZ)
Video Card: BFG 7800GTX $619 (look around Dell.com to get this for $491 or less. Check out the [H]otDeals section for more info.)
Hard Drive: Maxtor 7200.16 300gb SATA $200 (good choice)
Mouse: Logitech MX518 $40 (better than the Razor and cheaper)
Mobo: Asus A8N-SLI $140 (no need to spend a lot of money for SLI if you aren't gonna get it)
PSU: Antec NeoPower 480W $116 (can't argue, but if you want silent try this Seasonic S12-500 $129)
Optical Drive: NEC black DVD burner, etc. $46 (the sony was discontinued)
Case: Aerocool $59 (you can pick a different one if you want, I just picked the cheapest one with 2 120mm fans. Fans are important.
total: $2313
Ok, so I hope you use my suggestions, they really are a much better buy (good performance to price ratio) than the other stuff you had.
do you need an OS?
If you can really spend $200 more, how about the Dell 2005FPW (20.1") $501 widescreen LCD? You will be able to fully use your 7800 for sure there. If you can save a few hundred more than that, the ultimate in size is the Dell 2405FPW (24") $959 widescreen. I think if you look around the [H]otDeals section you may be able to find some promotion codes to further reduce those prices.
If you need to save some money, get a 3500+ Venice or 3700+ San Diego A64 proccesor. You can also wait for the new X2 to come out next month, a 3800+ I think (or do they call it 4000+? Not sure) at about $345.
In closing:
Alex A. said:
Choose anything you want for a case i suggest a Antec P180 or a Roomy Lian-Li PC-73SLB or PC-7077B
...but get at least two 120mm fans (1 intake and 1 exhaust).
Wow, thanks for all that info.
What do other people think of it, good compnents?
As far as OS I have that taken care of...
Hey, I just wanted to brag about my new thoughts on building a new PC. :D
You can wait next month for the next cheaper dual core, the X2 3800+ and a cheaper 7800 GT. After being out for a month, I think both will be available at street prices for about $700 US.
Both would be only $100 more than one 7800 GTX when they came out. :cool:
