Working (various programs, none of them use a lot of resources), gaming, watching movies
~$2000
3) Where do you live?
California, Silicon Valley
CPU, RAM, case, video card, hard drive, DVD drive, sound card, CPU cooler, possibly power supply
PC Power and Cooling 610W power supply (will it be enough?)
6) Will you be overclocking?
I plan to use the Sandy Bridge i5 2500k, so yes
at least 2 27" monitors, but I'll probably have 1 for the short term
In the next 2-3 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Crossfire support, USB 3.0, SATA 6GB
Windows XP 32-bit, Windows 7 64-bit
~$2000
