Master of Shakes
- Nov 29, 2011
I was gonna get a Synology NAS but, because I want to use it as a download server I think WHS 2011 would be a better build for the money. Also, the consumer based synology product line seems rather underpowered.
Also, I'd prefer to use mini-itx and this Lian-Li case because... well.. its sexy as hell. LIAN LI PC-Q25B
1. What will you be doing with this PC?
I want to run Windows Home Server 2011 to accomplish the following.... File storage, streaming media (specifically 1080p mkv H.264 videos) to my media player (sony smp-n200, possibly a wdtv live or htpc in the future), downloading via jdownloader/other download applications (I download from mega), downloading via sabnzb/sickbeard, and unrarring 5GB+ files. I wish for it to be a 24/7 machine so low power consumption is a must.
2. Will you be overclocking?
Nope.
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
I was hoping to spend around $500 if at all possible. w/ or without tax. its flexible by about 100 in either direction.
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
USA, california. Fry's and they'll price match microcenter.
5. What exact parts do you need for that budget?
Case, motherboard, cpu, psu, ram, whs 2011, only one HD for now to keep cost down, I can add more later. I'd prefer to get a 3TB WD Red/green to start.
6. If reusing any parts, what parts will you be reusing?
None
7. What specific features do you need in a motherboard?
Raid for down the line. usb 3.0 would be nice. sata 6gb/s would be nice to but I don't know if it would really make a difference with the drives that im sticking into this thing.
8. What resolution output do you need?
Dgaf, I won't be using a monitor on this guy except for maybe setting it up initially and using VM.
9. Does this system need to fit into a particular space and do you need an optical drive?
Nope
10. How comfortable are you with custom case design/modification and electrical wiring?
Not very.
11. How important is the noise/silence of this sytem?
Not that important.
12. How mobile does this system need to be?
Not important.
13. Do you already have a legit and reusable/transferable OS key/license?
Nope, planning on getting WHS 2011.
14. When do you plan on building/buying the PC?
Next few weeks.
Thank you so much!!!
Nope.
None
Nope
Not very.
Not that important.
Not important.
Next few weeks.
