Help me build a gaming PC
wesdog
Hey all,
I'm looking to build a new PC primarily for gaming. The last time I bought parts was back in 2007 so I am totally out of the loop on what kind of technology is out there nowadays. The only thing I know for certain is that I'd like an SSD drive because I've heard they make a world of difference in system performance. My friends have told me that all I really need is an i5 (OC'd) and I'll be set. I'd like some professional opinions if you don't mind. I'm going to copy/paste the questions in the sticky and answer them so you have a better feeling of what I need.
Thanks in advance.
Primarily for gaming, work, and school. I play WoW, Dota 2, and I'll be playing Diablo 3 and Guild Wars 2 when they come out. I'd like for this system to be able to run those games on high settings without trouble (with the exception of maybe GW2 because I am unsure of whether or not the recommended specs have been released for that game).
I'd like to keep it under $1,000. Ideally in the $700-900 range. If this is unrealistic then let me know as I have some wiggle room but I would prefer to stick to the listed budget.
Pittsburgh, PA. Newegg used to have the best prices so unless there's a better alternative I'll be using them to purchase all or most of my parts.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need
Cpu, gpu, ram, mobo, heatsink, case, maybe psu? (see following question)
I think I can use my old HDDs. I have a 35gb WD raptor and a 225gb 7200rpm HDD. I don't store a lot of music, movies, tv shows etc. on my computer. I usually delete them after watching them. To give you an idea, right now I'm using ~28gb/35gb on my main drive, and ~60gb on my storage drive. I also have a mouse, keyboard, monitor, DVD drive, floppy drive that I can use. I basically need the core components (e.g. mobo, cpu, gpu, ram, heatsink, case). I'm not sure about the power supply. I currently have a Corsair HX520W. Will that be sufficient for newer hardware or will I have to upgrade it?
6) Will you be overclocking?
I would like to overclock for max performance.
7) 7) What is the max resolution of your monitor? What size is it?
1920x1080. 24" Asus LCD.
ASAP! :)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Unfortunately I am not really sure. Like I said before I am not very informed anymore. I am hoping my other answers provide enough information to answer this.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes. Windows 7 32bit.
Danny Bui has a nice template for cases and can point you in the right direction. But with a budget of $1000 I was able to get a really nice build started for you. Some money can be saved on your motherboard and others may have some suggestions, but this would be a great start:
I can't provide links right now but here's a list:
Asus P8Z68 Gen3/Pro Motherboard ~$190
Intel 2500k CPU ~$220
XFX 6870 1GB Graphics card ~$170
2x4GB DDR3 1333 8GB ~$40
Corsair TX650 PSU (This may not even be needed, i still have an HX520 PSU and I think it would power a 6870 just fine. Your call) ~$80
Crucial M4 64GB SSD ~$100
Cooler Master Hyper 212 Evo ~$30
This will keep you well under $900, and that's with replacing the power supply. Some others may have some suggestions for you.
For RAM on the Intel Sandybridge builds get DDR3 1333 @ 1.5v. If some money can be saved on the Motherboard/PSU combination then you can either get a better GPU or add in a newer more reliable mechanical hard drive. I would recommend the latter first and foremost, but only you can determine how important your data is.
EDIT: Also, I don't currently have the time to explain why I took the choices I did, but hopefully some of the others in here can speak on my behalf. You will get pretty consistent recommendations around here.
^ Solid build.
I'd recommend bumping up the SSD size, as 64 GB could get tight with a few of the larger games. B&H has the 128 GB version for about $50 more. (link)
Personally, I wouldn't bother with a 64GB SSD, I'd save up and get a 120+GB instead, or put that money towards a HD 6950 or GTX 560 Ti. I would just get the vanilla Asus P8Z68-V instead of the Pro, as the Pro only adds a couple of extra (Marvell controlled) SATA ports and 1394. You could also save quite a bit by getting the Asus P8Z68-V LE or LX if you don't intend to run multi-card, or by getting a Gigabyte or MSI P67 board (mid-range boards are around $120 now).
Thanks for the quick responses guys. I will definitely look into getting a more inexpensive mobo so that I can splurge a bit more on the SSD and GPU (I am thinking maybe a GTX 560). I don't intend on running multi-card, and the fancy features on more expensive mobos aren't really necessary for me. Also, do you guys agree that my current PSU is sufficient, or should I go ahead with the recommended upgrade from Cmustang87?
They are correct in recommending the V version rather than pro. Don't regret getting a smaller SSD. Get the 128GB Crucial M4 and be happy for a good while.
Here is a build slightly over your budget, but it also includes a new PSU. I don't trust a PSU from 2007.
$224.99 - Intel Core i5-2500K Sandy Bridge 3.3GHz
$124.99 - ASUS P8Z68-V LX LGA 1155 Intel Z68 HDMI
$39.99 - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
$89.99 - CORSAIR Enthusiast Series TX650 V2 650W
$289.99 - EVGA 012-P3-2066-KR GeForce GTX 560 Ti (Fermi) 448 Cores
$27.99 - COOLER MASTER Hyper 212 Plus
$174.99 - Crucial m4 CT128M4SSD1 2.5" 128GB
Total shipped: $962.28
Use promocode HARDOCPX215D to get 7% off the video card (~$20 in savings)
Choose your own case (Compliments of Danny Bui)
$88 - Lian Li Lancool PC-K58 ATX Case
$90 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$98 - Cooler Master CM690 II Advance ATX Case
$100 - Corsair Carbide Series 400R ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$130 - Lian Li PC-9F ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$125 - Fractal Design Define R3 Black Pearl ATX Case
$130 - Fractal Design Define R3 Silver Arrow ATX Case
$130 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$130 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$130 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$140 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$143 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$144 - Silverstone RV03B-WA ATX case
$160 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$164 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$170 - Corsair Obsidian Series 650D ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
Will put you slightly over budget, but this is a solid build.
Skillz, I don't think I can recommend him going over budget by spending that much on a GPU with the games he's playing. A 560 ti 448 is pretty beefy for what he's playing. He can save over $120 on the GPU alone and stay under budget. Then upgrade later.
Meh...
He's got a 1000 budget and he's getting his all his money worth on that setup.
Some of the games aren't even out yet, no idea what they might require. I'd rather be too powerful and within' arms reach of my original budget then saving ~$100 and have to upgrade sooner.
Well I over looked his operating system. It's 32bit, changes things up a bit.
Meh...
He own's Windows 7 32bit, which means he can legally install Windows 7 64bit with the same key.
Can anyone comment on this card? Just curious as to why it's so much cheaper than the 560. It has a 5 star rating on Newegg so I assume it's good, but I don't know as much as you guys do.
This is what I have so far as per your recommendations, just need to decide on a video card!
Case
PSU
RAM
Motherboard
CPU
Cooler
SSD
Thoughts?
That GTX 550 isn't half the card the 560Ti 448 is. 192 Processor cores, not even worth spending so little on a GPU for a gaming rig. If you're spending that kind of dough on the rest of your components, get a better graphics card.
Alright, thanks for the help. I think I'll go with the GTX 560 Ti. Hopefully this lasts me a long while!
Thanks everyone.
Thanks everyone.
Are you talking about the Ti 448, or just the vanilla Ti? There's a difference.
I suppose the 448 as that is what was recommended. I'm assuming/hoping it has the best price-to-performance ratio and will allow me to postpone any upgrades for a long while.
With the parts I listed and the 560 Ti 448, the total comes to ~$1100. Slightly over budget but Newegg offers a nice 0 interest payment option over 12 months which makes the finances much more manageable. This is probably around the same price I paid back in 2007, so I'm hoping this build will last me a similarly long time. Thanks again. :)
Yep!
Be sure to keep us updated with how the build goes.. go with the EVGA that Skillz recommended! Good luck!
Yeah I'll probably be ordering this week and putting it together by next week sometime. Now I just need to re-familiarize myself with how to do so! I just hope the cpu cooler is easy to install. The last one I had was brutal - left scrapes all over my hands, heh.
If you're getting scrapes on your hands from installing a cpu cooler, you're probably doing something wrong! :p
Well, that Hyper 212 is a super popular HSF, so I'm sure someone can help you if you have any problems.
very nice, glad you got something you will enjoy!
Just noticed this. Can you elaborate? Is it possible to download Windows 7 64bit off the Microsoft website with a valid key?
Actually, if that copy of Windows 7 32-bit is an OEM or System Builder copy, the person owning that system will have to purchase a new license for Windows 7 64-bit (which the last time I checked costs as much money as the retail upgrade copy of Windows 7 in each relavant edition - $99.95 for Home Premium, $199.95 for Pro or $219.95 for Ultimate). If on the other hand he purchased a retail copy of Windows 7, it should have both 32-bit and 64-bit install disks.
All of my parts came and I successfully built my pc earlier this week. It's very fast and I'm happy with it, but I'm having one minor issue that I hope you guys might know something about.
When I'm gaming, there are faint, wavy horizontal lines running across my LCD screen. It's not severe but it is definitely noticeable, and is very annoying. I've been trying to research this problem to find out what may be causing it, but I haven't found any answers from reliable websites like this one. I haven't gotten a chance to troubleshoot much yet. I plan on trying out another video cable to see if that fixes it. I've already tried both reseating the GPU and tightening the cable connection, but it didn't fix the problem. I've also updated to the latest drivers and made sure that it isn't a refresh rate issue. Does anyone have any ideas what this may be? If so, just leave some suggestions in this thread and I'll keep checking on it throughout the day. I'm stuck at work right now but I'll definitely try everything when I get home. It's really frustrating to have issues on a brand new pc. :(
Thanks in advance.
