First off, prepare yourselves, I'm completely new to phase change setups. Due to this I decided I better look for some input and advice from those that have already tried this, made mistakes, broken stuff, and figured out better ideas so that hopefully I don't make the same mistakes. I also want you to tell you if my plans are stupid, if I'm dreaming, and if I'm being a nub. I can take it I assure you, saving money and doing a better job are more important to me.
My current project is to do a custom mostly passive phase change system that will be able to cool my CPU and my 7970('s x2 soon) without breaking the bank. I also want it to be as upkeep free as possible, while not taking up tons of space. Whatever I rig up I want fresh coolant going to each separate piece of hardware individually then back to the cooler so as to keep an even, cold, temperature in all devices and throughout the loop for better component performance.
So, I already know whatever I end up doing I'm going to be doing some customization on the actual cooling components to allow fresh coolant to go to three different components from the start, then recombining them again so those are all known and expected.
I'm going to use this main post as my "log" to keep all of my needs, and progress in as this project goes on.
I know a basic list of items I'm going to need is: Vacuum pump, pressure/temp gauge, tubings and fittings, radiator, water blocks, and some type of non-freeze coolant. I have no idea where to start with these though, what components have good ratings and what doesn't, or how to set up the loop for best performance. I'm hoping this is where you all can provide me with some recommendations as to affordable well performing equipment, filling in any blanks I've missed in my plan, and instructions for how to set one of these systems up and optimize it as I'm doing it.
I'd also appreciate links to any parts you recommend, and if possible any trusted guides you all know of so I can study before I start buying all of my parts and start attempting to do this over the next month or two.
Your assistance please? I appreciate it!
