Help me before I break something.
Chickenleader
Finally got all my computer parts in to do my upgrade, a8n sli deluxe,3200 venice 2 gigs of crucial 1 gig each I think its m16FD the one with the little square ram ic's anyways Im trying to overclock this guy and I got no idea what im doing. I set fsb in cpu menu for 250 fsb for me m to 200 multiplier 10x and Hyper transport "what the heck is this" to 3x Ram was pushed up to 1.5. Booted fine first time and cpuz recognizes it at 2500 mhz and ram fsb at 250 and htt at 250. Ran through 3dmark 05 game test and it came back with a score almost at 6000 on a 850xt card. Do these numbers seem low and Is my fsb really running at 250 and if so Is that dangerous?
Read this and make sure you understand it all, then follow the procudure exactly.
I'm not quite sure what you mean by "Ram was pushed up to 1.5". Do you mean you set a CAS latency of 1.5? Oh, and just because the system boots into Windows doesn't mean it is stable, you need to run the Prime95 and Memtest programs mentioned in the guide I linked to to make sure your system is stable and will not crash.
That must be the Vcore, because there's no way your RAM would run with only 1.5V :D.
Roger that ram is 2.7 my brain is fried from playing with my new toy all day. My 21 inch trinitron decides to die on me on the day I get all my new parts in. I hate sony.
I dont get it ive got my hyper transport set at 3x dram at 400mhz with these timings 3,7,3,3,11,14,5,3,1 from top to bottom. CPU freq is set at 250 , Pci express clock at 100, DDR volts at 2.75 , cpu multiplier at 10x cpu volt at 1.5 and pci clock sync at 33.33mhz.
At these settings shouldnt I be getting 2500 cpu with a 200 mhz fsb on ram? What am I doing wrong and yes I did read the guides but went over my head a bit. Does it matter if I run my ram at 250 all the time? Im running through prime95 now and so far so good and ive ran several passes of 3dmark05. Looks like this http://www.newegg.com/Product/Product.asp?Item=N82E16820146545 is still pretty good ram even though its differant smaller sqaure chips on it now.
AHH nevermind finally figured it out gotta drop the ram fsb down to 333 in order to get it close to stock 200 if you got the cpu fsb cranked up high..
