Alright, I have spent the past 2 months setting up, configuring and uploading my media to my new media server. Now that I have it all setup and running smoothly, I want to backup it all up so I don't have to redo all the work I have done.
First, I would like to ghost my c: drive so I can re image it without having to spend over a week installing and configuring everything again. I have worked with ghost before (Only ghost server though. We had a dedicated PC setup at my old work that we would connect to the PC we were going to ghost) so I am familiar with the process, but I am not sure which program would be best for me. I have no problem paying for software if it is better, I am just curious if there is anything free or cheap out there that works really well for imaging a 30 gig drive to an external hard drive.
Second, I would like to backup my 2 media drives that hold my saved TV and saved movies. Saved TV is on a 1TB drive and my movies are saved another 1TB drive. I am looking for a network storage solution (I have used all of my available SATA ports in my server. Plus I don't consider anything that is directly connected to the computer a backup, I have seen crazy things happen to backups) that will automatically look for changes on these 2 drives and clone them to the network storage. Since my movies drive is getting full, I wanted to purchase 2 1.5 TB drives and use those for the movies drive and backup drive. I would then use the old 1TB drive for movies as the backup drive for the saved TV (They are different drives, 1 is a seagate, 1 is a WD. Does this matter?). Basically, what is a good network storage device that supports 1.5Tb drives and will automatically clone 2 different drives on my media server?
Thanks for the help!
