bcracer220
- Dec 7, 2006
hi guys,
i am looking into building a watercooling system for my current setup. i have been doing research in the xs forums as well as this one, but i need more specialized assistance in choosing the actual parts.
Timeline: I am in no rush at all to build this setup. I would like to have it done by mid December, and I am starting this early because I really want to spend the least amount possible, and such a large timeframe will give me a higher probability to find the parts either on sale or second hand for a discount price. I would however like
to have a parts list by the end of this long weekend (before school starts).
What needs to be cooled: I would like to cool my E6600 and my north bridge. My rig is listed below, and my temps are just getting too high for the overclock I want. The chip overclocks very well, but heat is holding me back. I am not 100% sure yet whether or not i should include the north bridge in the loop, however my research tells me that it will only add 20 watts of heat, so I am leaning towards adding it. I am not at all for cooling the GPU because the heat output is way too high, I'd rather just upgrade the air cooler if at all, and my GPU cooler (stock one for 7900gtx) is plenty. From what I have researched it seems like putting the GPU in the loop too is going to be way too expensive. I would also like it to be very quiet. If i could use my af12's to cool the radiators that would be ideal, they push nearly 60 CFM and you cant even here them. I have 2 already, and for mounting them to the radiator i could just use hot glue (I was thinking I could, again your suggestions are welcome). Also, my next upgrade will probably be quad core penryn, so just keep that in mind.
My Rig:
X-Dreamer 2 by Aspire
xeon 3060 l632a @ 3.4 (1.33 volts 13 hours orthos stable +), runs on 8x multi
p5b deluxe wifi
ballistix tracer 8500 ddr2
7900gto @ gtx
corsair hx 520 power supply
seagate barracuda 7200.10 320GB (in a silent drive enclosure)
audigy se sound card
big typhoon
Current Temps: This processor can easily do 3.6 with just 1.42 volts, but my big typhoon gets to 70 C in orthos which causes instability, it just can't take the heat. I don't want to keep spending money on air cooling, I just want a setup that will allow me to keep my processor very cold, and get the setup done once and for all.
Overall: I'd like to build a setup that will be able to handle any processor from here on out. The good thing with just sticking to processors is that we know for sure the thermal output will always be decreasing rather than increasing, giving a better chance that this setup will be able to be utilized for much longer. The less parts the better, so having a seperate pump and everything wouldn't be ideal for my setup. If I could have a waterblock with built in pump that would be ideal.
Thanks in advance, please help me as much as possible, I really have no idea where to start!
My Rig:
p5b deluxe wifi
7900gto @ gtx
big typhoon
