Benton The Race
- Nov 3, 2005
Well my E6400 was having very high temps(45 degrees celsius stock idle with ninja!). So, I decided to work on cooling it down.
-Lapped the E6400 and ninja
-Purchased AS5
Now, how should I go about applying the AS5 correctly? Should I first apply a little bit to my finger then work it into the E6400 to fill any scratches, then apply a rice sized glob in the center and push the Ninja on? Is this the best way?
-Purchased AS5
