Help! Master Boot Record problem?
morfinx
My 40GB primary HD (EIDE) is failing, so I got a 160GB (SATA) to replace it. I wanted to keep all of my settings so I don't want to do a refresh install.
I used a free partition cloning software (drvclonerxp) to clone the boot partition to my new HD. I then went into WinXP recovery console, and did "fixboot" and "fixmbr" on the new partition. Long story short, 8 hrs later, I can now boot into the new partition, but only by booting into the old HD first, whose boot.ini I edited to direct the boot path to the new HD. If I try to boot directly from the new HD, then nothing happens, system just hangs and the boot menu never comes up. I thought it could be the MBR, so I went into recovery console and did "fixmbr" again, still no go. What can I do to fix this?
P.S. in Disk Management, it shows my old HD as the "System" partition, and my new HD as the "Boot" partition.
why not use ghost to clone the drive. i would not trust a free app to copy my main partition and expect my data to be secured. spend some dough and buy ghost.. IMHO
do a windows back up including system state. format new drive and install windows. restore back including system state and all of your stuff will be back. will require third drive or slave drive on 2nd drive
and in advacned options on restore dont overwrite newer files as you are changing from IDE to sata and it will need the new drivers... done it a dozen or more times. works great
