Help Making My Own DVD's
PawNtheSandman
I have AVI files or MPG files I wish to burn to DVD.
I was using WINAVI to convert single files into DVD format, then using Nero to burn them. This is fine for single files.
But if I want to burn several episodes of a tv show to 1 dvd, how do I create a menu to choose which episode to play. Also, is there a way to shrink how big the DVD files are so I can fit more episodes per DVD? Thanks.
you should be able to create a menu using nero just get them all converted and ready to go on the disk and then look through the options.. i know its possible i have done it before.
when i burned to a viewable dvd, nero automatically asked me to make chapter selections and asked what splashscreen I wanted
