Help! Mad at my 7900GS.
BTK17
My stock clocks of my XFX XXX Edition 7900GS is 600/1,600 MHz
I have it at 615/1,900 MHz stable. XFX gave more volts cuz it runs hot.
I reduced geometric delta to 0 and it made the mem go insane (geo clock usually helps core =/). But it does not help more then 1-2 fps from 850 MHz to 950 MHz as I am not mem bandwidth limited. I need more core.
But before I do a vgpu is there anything I can try to get core clock up?
It won't even go to 615 MHz. A beastly 15 MHz oc! I tried VID 0 but as expected didn't work.
Also I have no multimeter/solder and XFX PCB is a different design so i don't know where to look.
3Dmark05
http://i10.tinypic.com/631m0ia.jpg
Anything I can try before VGPU?
150MHz was already squeezed out on that card. Of course you can't expect that much more of an OC without a voltmod. Why would you be mad at it? lol...
Hey...its true. 450mhz stock clock, you're running 600. It's pushed to the max!
True to form, your card isnt guaranteed anything other than the stock clocks it came at! :)
doesnt mean you cant run a little bit more juice through it to grease things up a bit though...
