Jimmy Swanson
- Jul 16, 2004
Hello,
I have never used a Mac before but volunteered to try and fix an issue a neighbor is having. Apparently, he had downloaded updates from Apple and now it boots to the Darwin login screen (black screen with password/login prompt). If I simply type "exit" it seems to quit out as the screen turns the normal background color but then it shows the login screen again. Any help would be appreciated. I figured I'd see what I can do as my neighbor was actually just going to go and purcahse a new computer.
