Help! Low 3D Mark 2006 score!
Hi there, I recently bought a system with the following specs:
- AMD Phenom II X4 955BE 3.2 GHZ
- Gigabyte Geforce GTX 460 Fermi 1GB
- G.Skill 2 x 2GB Ripjaw DDR3-1333 CL-7-7-7-21 timing
- Seagate Barracuda 7200.12 1 TB SATA2 drive 32MB cache
My 3dmark 2006 score is only 17672 with this breakdown:
SM2.0 - 6763
SM3.0 - 8566
CPU Score - 4908
Is there something wrong with my system that I need to look into? I would think I can get a much higher score with my system build.
Please advise what I should look into to improve my score. I had computer assembled by the store so they may not have optimized all the configurations.
Thanks!
Do your games run fine? Are you having fun?
If yes
Ignore 3dmark
else
Keep benchmarking
Play a game, don't run a render test ;)
Looks fine from the rig specs. You could run vantage and push the card a little more though. But it looks fine indeed.
Dont get hung up on 3D marks scores...its a good tool to test out overclocks on your rig to see if they make a difference ,or to run to see if your clocks are stable.
but there are so many variable from one machine to another, its rarely a good indication of actual video card performance, as compared to someone else's score
if your games are playing smoothly, that's all that matters
Hi guys, I used PassMark Performance Test 7.0 benchmarks and found that my CPU and G3D scores are way underperforming comparable systems online.
My scores are:
PassMark Rating: 1671
CPU Mark: 3307
G3D: 1679
Memory: 779
Disk: 679
CD: 368
I noticed that comparable systems which score much higher than my system all use either Windows 7 64-bit or 32-bit while my system is currently running WinXP 32-bit.
Does the OS I use affect the benchmark performance by a lot? I mean does WinXP not take full advantage of my system specs?
I understand that gaming is more important but since it's a new system for me, I would like to make sure it's running optimally in terms of benchmarks before I forget about benchmarks and just focus on gaming :)
Well, for one, XP doesn't support DirectX 10 or 11.
And by running a 32-bit Windows OS, you are limiting your available RAM to a max of probably less then 3GB due to your video card being 1GB.
32-bit Windows available RAM is: 4GB - video card RAM - some other reserved memory space.
