Diesel-man3000
- Jun 25, 2007
Ok i recently bought these and i found out theres a problem with one of the inputs on the amp which makes one satelite weaker than the other i first noticed it when turning it up and then realized that it is stronger in every area vocals to beat.So i am going to take these back and i might get them from bestbuy this time,but i am willing to spend up to 200$ on speakers so i am looking at the klipsch i think the logi's sound a lil thin sometimes but i like them for the most part especially the sub,I would like to hear yalls inputs on the klipsch.I also found to get static outta these speakers and distortion at higher volumes i had the same with my old logi x-240s.I currently use the onboard sound on my biostar tforce 560 board.I am running vista i am also wanting to know if i upgraded to a sound card would my audio experience be better even if i end up getting the logi x-2300 thx speakers.I am looking at the sound blaster audigy SE and the turtle beach rivierra i think.
Also do you think the logitech g51 would be a good deal for my 360 and music listening along with movies maybe just as good as the 2300's.I would also need cable extensions to mount them on the wall opposite wall the tv would be on so i could mount them on the wall.
