i have recently bought a new Isis 42" 3d HD TV when i try to plug my HDD to it via USB the media browser appears but every time i select a film it say unsupported format now bare in mind i have checked to see if the tv supports the files in question and they do so.was wondering is it a simple case of update the firmware on the TV,if so how ive never updated a tv before plz any suggestions would be a massive help thanks again peeps.PS does anyone know who manufactuers Isis tv went on toshiba website after looking on the web and found someone suggested toshiba and typed in the product code to look for firmware nothing comes up.thanks again ;-)
ps the hdd im using is a wd my book 1tb,which i used with a toshiba 40 inch and a 32 inch samsung with no problems but trying to get a film to play on the isis tv is so frustrating i just cant find an answer im hoping someone would of had this problem with a similar tv
