I have a new SATA HD that I am trying to install with Win XP Pro. When I built my system I intentionally left out a floppy drive. Its outdated tech and I hate those damn things. I've had Win2K on the system for a year and had no problem installing that to the old IDE drive I was using. The problem now is that it appears I can't install XP Pro to my SATA drive without a floppy. I have a bootable CD with all the old Win98 tools on it (fdisk) but, of course, fdisk won't work because it doesn't recongnize the SATA drive as a fixed disk. Similarlly if I use the bootable CD to load CD ROM drivers and then run winnt.exe from my XP disk the install immeadiately fails because it says it needs a drive to install to (I never get to the F6 option of providing HD drivers during XP setup). The only solution I've been able to find is to install XP from floppy and, when prompted, hit F6 and provide the proper drivers. Does anyone know of a way to install XP Pro to a SATA HD without using a floppy?
Thanks for any help you can give,
Dane R. Vinson
Dane R. Vinson
