I am getting stuck here.
5 Configure The Network
Because the Ubuntu installer has configured our system to get its network settings via DHCP, we have to change that now because a server should have a static IP address. Edit /etc/network/interfaces and adjust it to your needs (in this example setup I will use the IP address 192.168.0.100):
vi /etc/network/interfaces
How do I physically go about editing this? I can overwrite the text that is in there by default, but how am I supposed to 'save' my settings per say?
INSTALL GUIDE
I then also get stuck on the step after that, not being able to get the name to display as it states. I am going to try again now (been a week or so) and I will be able to give more detailed explanations.
Code:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
INSTALL GUIDE
