Help Installing Tuniq tower
eternaljammer
It seems the chipset cooler on the bottom of the motherboard prevents me from installing the backplate for the Tuniq. How do I secure my backplate?
I used to have a DQ6 and I simply removed the backplate in order to fit a Zalman Cooler.
It's very simple to do. Just push the white pins out and remove 2 or 3 screws from the top.
It's either that, or find longer screws for the tuniq (If possible). Some people were able to use longer screws (custom) with other coolers.
