Help installing sound card
IsaacMM
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series is the card i have, in the manual it only says that i should put it in a PCI slot. Do i have to plug any power cables on it?
If there is a power connector on it then yes.
My Asus Xonar I have to attach a floppy power cable to it for it to work. No idea about yours without looking at it.
Here are some pictures i took from Newegg, hopefully you can help me now
Does the manual say it needs a power connector from the PSU?
There is no manual, it only has a "quick install" manual and it doesn't mention that it needs a power connector
