Help installing new IE7 Update KB960714
LurkerLito
I can't seem to get this to install anymore since my system restore. I have tried both the standalone and the one on windows update on my Vista64 ultimate machine and it always fails with a error 80070246.
Earlier this morning I installed this ie7 update, but I was having issues with a bad physx install from yesterday when I installed the cryostasis tech demo. The only way to correct the physx problem was to restore back prior to the cryostasis install. But that also removed the IE update I did this morning. I thought it would be just a reinstall from windows update but it won't install anymore. Does anyone have any idea how to fix this problem? I check the files and they are the old IE ones listed on MS' site, so I do need to upgrade. I just don't know how to now :confused:
