http://www.newegg.com/Product/Product.asp?Item=N82E16814102492
or
http://www.newegg.com/Product/Product.asp?Item=N82E16814130203
Uses? HL2 and WoW. They are both AGP, and I want it to last me a while before I upgrade everything to pcix. It'll probably be 2 years before I upgrade.
Or, if you have a better card under $300, hit me up with it. Thanks.
-----------------------------UPDATE--------------------------------
Where is the 6800GS? I waited a while and it still isn't out, even though several sites said "a week."
Kind of annoying, because now the 6800GT is no longer at new egg for agp.
So, if any of you have info about the agp GS or see the GT somewhere, I'd appreciate some linkage.
or
