Help in deciding 20in widescreen
Kid8
Im looking to get a good 20in widescreen monitor just don't know what one to get. Was thinking of the Dell 2005 or an Acer AL2032WA or Gateway FPD2185Wt. Which is the best bang for the buck and best for long term use. Also if there are any reviews on the acer i would very thankful if you could post a link to it. Also if there are any other good widescreen monitors out there that i have missed. Don't really want to spend much more than $500 tho. Thanks in advance for the help.
Link to the Acer:
http://www.newegg.com/Product/Product.asp?Item=N82E16824009060
Link to Gateway:
http://accessories.gateway.com/Acce...inch+LCD_381955/7005483_proddetail.htm?seg=sb
Link to Dell:
http://accessories.us.dell.com/sna/...y_id=6198&cs=19&l=en&Page=productlisting.aspx
