Help If you can/would plz
Northern
If anyone could Instant message me on AIM im having a problem getting a 2.8c on an Abit AI-7 with Mushkin 512 222 to install XP first system build and first system since pentium 2. Keep getting errors that something is wrong with the atapi or some crap and the xp install fails and restarts.. any help would be great
Ryolitewildfight is my AIM i use aol on this computer. Thanks
you'd probably get more help if...:
A)you reformatted your first post (skip lines, makes for easier reading)
B)you posted (in excruciating detail) your problem and full system specs here, as most people will be more willing to post back then AIM with you (also, consider the fact that some people might not have the time for a lengthy AIM convo, but could give you the 4 words that will fix your problem...)
