Help IDing Dell Lottery Winner
night_2004
So I purchased a 2007FP monitor and got it delivered today. But the serial number indicates its an S-PVA panel.
I'd like to confirm it is S-PVA though, since obviously things might have changed with those serial numbers.
Anyway, I'm not paying $400 for a 20" S-PVA monitor and I intend to exchange or return if it isn't S-IPS. But I want to be sure.
One easy way is to check for gamma shift; I find that the grays on this forum are where I see it the most on my VA monitor. If the grays look different on the left of the monitor than on the right, you have a VA monitor. Otherwise, likely IPS.
It the squares in this picture are easier to see from an angle than when viewed straight on, you have a VA
It is DEFINITELY an S-PVA monitor. The 2007FP reacts the same way that the 2407WFP does (and the 2407WFP only comes in S-PVA).
The 2007FP is far too blue for me, and even after calibrating with Spyder I just cannot be satisfied with it. Its too dim, so I'm going to request a replacement and hope I get a better one.
