Help Identify this Socket A Heatsink!
Kmical
It's a big ol' chunk of copper, with wire clips to hold various 80mm or 92mm fans. It did not come with a fan pre-installed.
Thanks in advance for any info that you can provide.
Why that looks like my old ThermalRight SLK800 heatsink I used to have... I believe they also had a 92mm version (SLK920) I think. It worked pretty well.
92mm version was the SLK900. I had that one and it worked very well. Run it with a Vantec Tornado and you have a crazy air cooler, howver, the noise is pretty high!
Yeah, ThermalRight SLK800-A
I was about ready to say it was the SLK900, but it doesn't have another ridge for a 92mm fan.
Cool! Thanks for all the help. It is/was paired with an 80mm Vantec Tornado - combo pictured below - but I needed to remove the fan to get some good pictures of the heatsink.
Now that I've been reminded what it is, I'll be putting it up with a bunch of stuff on the FS/FT Forum.
Thanks again, everyone!
Wow, memories. I used a Delta fan just like that one at 5v.... And it still was loud :mad: LOL
I bought a couple of the old outrageous CFM Delta fans and mounted them on a AMD Slot A CPU in a mini-tower case. Joked with my friends that the case could hover a couple of inches off the ground if I left it on its side with the cover removed ;)
