martinmsj
- Mar 3, 2005
System Specs:
6 GB DDR3 1600 (have them running at 1333.)
i7 920 @ stock 2.6 GHz.
Rampage II Gene
Zalman CNPS9900 LED Cooler.
Here is the situation.
I installed the CPU + Zalman. At first my temps were going into the 60s just opening or installing a program. I looked up the instructions and realized I put the Artic Silver 5 incorrectly. Looked at the instructions online and redid the job.
Situation now.
I looked up the hardocp i920 overlocking and heat article. LINK
In particular this graph.
At first I set the memory in the bios to run at 1600. Then I set the processor to 965 clocks (3.2GHz) using the CPU level up utility from Asus.
My temperatues at idle were 47-48 and when installing stuff it would go into 52ish temps. Running a game (World of Warcraft) it would go 52-60ish. I'm running the fans on silent mode to standard mode.
Kyle says to add about 7-8 degress since his testing was done on outside of a case. I also live in Miami, Florida.
One thing is I don't know how to set the timings for my memory so I decided to run everything at stock and the memory at 1333 below the rated 1600 and wait till Kyles review of this particular board.
My temperatures are still the same at stock clock (2.6 GHz) as when overclocked to 2.8 Ghz and 3.2 GHz. Asus Probe II sounds the alarm at 66-67 degrees. I ran an Anti-Virus scan while running Windows Updates and browsing the web and I gotas high as 70 degrees on stock. The windows CPU utilization widget reports 18-20% usage of the CPU during all this.
Should I be worried? Adding 6 degrees to Kyles 3.8 Ultra test kind of match up.
Idle 48 25% 72 while mine are Idle 45 (not doing anything) to 66 degress at 20-% (anti virus scan, windows updates, web browsing.)
Though his are at 3.8 on the Ultra and mine are at 3.2 on the Zalman. Also, i'm using a tube of Artic Silver 5 from like 3 years ago.
Help
Update. Added a Fan to pump air into the motherboard area. So far I'm on 44C System and 76C at 2.6 GHz I7 AT 100 LOAD across all cores with Hyper Threading enabled.
Update:
My idle now is 42 C.
I added a fan in the front compartment of my Antec P180. (Has a spot there for a fan and a dust filter.)
I also re-greased the CPU. Here is a picture of it before. Testing right now to see under load. (I'm on my notebook.)
OC'ed to 3.2 GHz I get 84C with Intel Burn Test program at 100%. Opening my case drops the temps to 79C at 100% load and oc'ed to3.2GHz. I need more air coming in or going out. Sigh. Was hoping to do 3.2 OC easy maybe 3.6.
The Blue rectangle is where the new fan is. Blowing cool air into the area designated by the elipse.
This is the CPU area. I have two vents with hooks to attach fans to both. Should I attach a fan to the top vent blowing cool air down to the zalman? Or should I have a fan blowing air out the back vent behind the zalman?
Update:
Adding a fan to the vent behind the Zalman dropped my i7 (3.2 GHz) idle to 42-43 and my temps at 100% to 73-75 with hyper threading disabled using IntelBurnTest. The temps go as high as 76 but most of the time 73-74. And my room is kind of hot right now.
Rampage II Gene
Situation now.
Help
Update:
Update:
