Help: I need suggestions.
PawNtheSandman
I had my old Chenbro net cube case seen here:
Well I decided to get rid of the BG Micro 20x2 VFD. That left me with an unsightly hole in my case. I took out the tinted window and made the window bigger so now there is only 1 decent sized hole on the side. I used C car molding around the edge and glued plexi to the inside. Fine.
What I need suggestions with is the front of the case is vented. On the bottom all the way under the power switch, is an area for a 120mm fan which I have inside the case. Should I cut a hole in the front of the case and put in a tunnel so I am getting direct unrestricted airflow?
I was thinking about doing this, as the people who did it on the Yeong Yang cube case made it look nice and clean, but on my cube, the front of the case is vented so I am thinking it would look ugly. What do you think?
