Help! I need confirmation on my troubleshooting
FiZi
I've got the following system
Asus K8V SE Deluxe
AMD 64 3200+
1.5gigs of RAM (Kingston)
120gig IDE Maxtor Hard Drive
Radeon 9200
Today I was moving components from my old case into a new case so I could attach the Zalman CPU Fan I just purchased. When I was removing the old OEM CPU Fan/Heatsink from the CPU it ended up ripping the CPU out of the socket. I checked the socket and there was no visable damage. I checked the CPU and it had some bent prongs. I fixed the prongs carefully with a pocket knife and then finished moving all the hardware. Now when I try to boot up a few things happen.
I was getting a DMA Controller Error ... Fatal Error and the system would halt and I couldn't get into the BIOS. I resolved that by resetting the bios using the jumper.
I then got into the bios, made some changes (disabled raid and sata) and then tried to boot again, same DMA error.
I reset the bios again with the jumper, left everything on default in the bios and just tried to boot. The Windows XP screen would lock up after the bar flew by a few times.
I then moved the IDE hard drive to the secondary channel using an old IDE cable not a UltraATA cable. The computer started booting into windows, and it did a disk check, fixed some errors and then booted into Windows. I was only in windows for 30 seconds and it locked up again giving me a blue screen of death with the error: Machine_Check_Exception.
I removed the CPU and put in a known good CPU and tried to boot again and it got me into windows. I was there for a few minutes and then it locked up. I went into the bios and changed the date to the correct date and now I get the DMA error again.
Also now that I've given up and turned it off the thing keeps turning itself back on.
I just tried the CPU I bent the pins on in another computer and it booted and ran PCMark04 CPU tests a few times with no problems.
I also just removed my floppy and HD and left just my DVD-ROM in and tried to boot into Knoppix and all I keep getting is the DMA error.
So since I've ruled out the CPU I'm betting the motherboard has gone bad either in the transfer from case to case or when the CPU was ripped from its socked thanks to the awsome AMD Super Glue Thermal Paste they put on their OEM heatsinks and fans.
Am I right in this assumption?
are you using the same psu from your old case? i suggest reinstalling the motherboard one more time. other then that it sounds like your motherboard is borked :(
Gotta love that AMD Super Glue Heat Goo! Patent Pending :p
On topic...
I think you've done the right steps, but I would try everything else attached to the mobo: power supply (as suggested), RAM, video, hard drive, optical drive, to make sure that they are not causing anything in the BIOS to go funky. Apart from that, I would agree that the motherboard my have some problems. Follow that troubleshooting through but, to make sure.
To me it sounds like your Mobo is dead now. you might have severed a small connection and not have even known it. I would look at the pathways and see if you see any that may be broken. Not sure if you could even fix them if one is broken. I have known people to sauder them back together weather that works or not I have no clue. Good luck man
I've seen this before: you need to upgrade your mousepad, preferably to an ergonomic "boob" mousepad :D
Bona Fide said:
Pardon my ignorance, but what's a riser? :confused:
i think hes referring to the motherboard standoffs (you know those things you mount your motherboard on..)
