Can someone plz help me =I think I found the root of my problem but Im not sure heh.. I figure its my PSU. I bought my PSU because it had really good reviews and recommendations and I think it had 100% 5egg rating on Newegg.
Here is how I figured it was my PSU causing all my problems..
1st scenario: Windows instability, wouldnt be able to open up a certain amount of programs after about a hour use of the computer. Thought it was my RAM I RMA'd it and problem still occured. Ran diskcheck on both my harddrives and it found no bad sectors. Reformatted and had only the mobo drivers installed and it still occured.
2nd scenario: Sometimes, not all the time, when I leave my computer on overnight it would be shut down in the morning. It's not windows autoupdate because this happened even when I was running memtest and when I was formatting my harddrive through xp cd.
3rd scenario: I took apart my computer once again, rewired and wire managed my whole computer. But this time I set 4 of my 120MM fans on "high" settings and turned on my comp. When into bios and the computer shut down on its own.
I have 7 120MM fans on my case... Is it because 700W isnt enough or is my PSU faulty.. Can anyone help me on this I havn't been able to use my computer stabley since December of last year and its really wearing me out
. I've been through 1mobo rma, 1ram rma, and a GPU stepup(thought my card was at fault so might as well upgrade lol). I think I might even cry lol =\.
680i A1 Latest Bios/Drivers
e6600 @ 2.4GHZ
8800GTS 320MB
Crucial Ballistix BL2KIT12864AA804 2GB 4-4-4-12 @ 2.2V
WD Raptor X 150GB 10K RPM (SATA)
Seagate Barracude 320GB 7.2K RPM (IDE)
Seasonic M12 700W PSU (http://www.newegg.com/Product/Product.aspx?Item=N82E16817151031)
e6600 @ 2.4GHZ
8800GTS 320MB
