Help , I lost my data.
I lost all my data and it is raid 0 configuration disks , so I would like to know if it is possible to put a raid 0 array on another controler to get my data back .
Please I need Your help people.
Assuming it's your controller or mobo that died you should be able to hook it up to an identical controller and read the data. Any identical chipset or controller should work fine so it doesn't necessarily have to be a board from the same manufacturer. If the drive died you could be out of luck. You could send it off to get the data recovered and it might still work but no guarantees.
