Help!! i am in big trouble!!
sdb_93
im trying to learn about the insides of computers and how they work. i took the side panel off of my comp. and started looking at stuff. i moved around wires to get better looks at stuff, but i unplugged nothing. i put the side panel back on my comp. and plugged everything into the back. i turned on my comp and it turned on (all of the lights and fans) but the monitor stayed black.
i did this on a carpeted surface (if that means anything)
what do i need to do to get my comp working again?
Its posible you caused damage with a static discarge. Try reconnecting all your cables on the back of the PC.
maybe your monitor isn't plugged it?
Is the power LED on your monitor orange or green?
i've reconnected the cables on the back like 6 times. no luck.
the monitor is plugged in and on. the light when i turn it off and then on is green but then quickly turns orange.
Any other suggestions/ideas?
Do you know if any fans are spinning? Do you hear the HDD spinning? Do you hear a POST beep?
I've had that problem twice. Both times my RAM was to blame. The first time one chip was defective, and the other time one chip died while I was on vacation for 2 weeks.
The computer sounds as if you turned it on, but nothing will show on your monitor. Try taking out all your RAM and putting it in piece by piece to see if that's it.
yes, there are fans spinning. but i dont think i hear a beep.
i tried removing each of the ram chips. no luck.
i dont think that i dislodged the video card, i just secured it a bit, and still no luck.
can you try running a different video card instead....
sounds like its the video.....but don't quote me on that ;):D
If your video card has extra power to the back of it......did you accidentally unplug it while you were rummaging around????
I'd systematically go over each connection first. If that's ok.....
Then, remove the battery from it's holder and wait about a minute, replace the battery. You need to turn off the PSU and unplug it before you do this.
If this works, your BIOS will be reset to default, so you'll need to go in and reset things if there is anything custom you did in the BIOS.
thanks a lot for all of your help guys. i tried all of your ideas but nothing seems to work, i took it to some computer expert that works at a comp. repair shop, he says he cant figure out what it is. now he's going to try to put each of my parts in a different computer and figure out whats causing it.
Thanks again,
sdb_93
sounds like static discharge.
The lesson learned here is to make sure you dont have any charge on you before you mess with shit inside your pc.
Ya, it probably is electro static discharge. the guy at the computer repair shop says that he cant figure it out. he wants me to go in and show him exactly what i did when i took off the side panel, its so bull. basically i'm just gunna go in and stare at it and touch some stuff... cause thats all i did.
did he try to isolate it? what component failed?
buy a wrist strap and ground yourself the next time:D
I have never used one. I just touch something metallic to discharge myself BEFORE I reach into the case, and don't work on carpet ;) Not to mention in this area, humidity is so high that a charge typically never builds up...
Static discharge has got to be a myth. I'm so careless when I work on my computers. I've had open cases running with cats laying inside the cases, no problems. I'm in the desert too, where static is a real annoyance.
ESD has a latent effect most of the time. So while you may not notice anything now, you parts may die sooner than they were supposed to.
I think it's luck... I have never used a wrist strap either, I just ground myself...and then there was that time my kid knocked a full beer over, into a running PC.... that was three years ago, and it still runs fine to this day....
And there is always that as well:)
