Help Hosed my Abit BD7
MrSteel74
Ok I was doing a Bios update and my power went out. Now the board won't boot or anything for that matter. I'm guessing the Bios got hosed when the power went out. I know sometimes you can try to redo the flash using a floppy disk but I don't remember all the switches and commands for it. It uses the awardflash program. If anyone has any clues or suggestions I'd greatly appreciate. Otherwise I'll have to breakdown and spend $25 on a new Bios chip.
If the bios is hosed after trying to reflash/reset. You'll need to either try hot flashinng the bios or get a new one from the board maker. Google to learn about hot flashing.
I can't hot flash cause I don't have access to a working BD7 board. what i'd like to do is try and use the boot block on the bios. I just don't remember all the switches to do it. I know you put a line in the autoexec file. It's something along the lines of awdflash.exe bios.bi /s /rr /y or at least something of the like. I just don't know what switches to put in. I've done this once on a different Abit board and it worked like a charm after figuring out the right switches.
