I have a cable modem that goes directly into a 5-port gig netgear switch, I then have one computer hooked up to the switch(I can get onto the web fine with this one) then I have the my wireless router hooked into another port on the switch, problem is, for the life of Me, I can't get the wireless to want to work. Can you guys offer any advice for me, possible how to get into to manage the switch or what settings I need to change on the router. I assume I need to set it up on a static IP, but how am I suppose to do that if I cant log in and tell the switch that.
ANY help would be appreciated as I have been racking my brains out over this for a couple of days, or is this even possible?
Thanks!
Mike
Thanks!
Mike
