Well I wanted to game on the 55 inch so I guess there is no way around not having to use a wire through the house..If I Could run the wire I would def go HDMI but it seems running the wire might not even be possible.The Asus motherboard I have allows you to control the PC remotely. BTW how far can an hdmi signal go Ive heard longer than 50ft might not work? Appreciate the help
