Help Help Help
Hikaru IchijoSL
I has all the components I need for my new system and need a good case
80-90
Have enlight 420psu
Must have:
Front door
tooless(if can stay in price range)
Front Firewire
USB
come or have space for 4 fans
side window with space for fan
fan control (if can stay in price range)
temperature gauge (same a above)
80-90
Have enlight 420psu
Must have:
Front door
Front Firewire
USB
Hmmm, you'll have to do some shopping yourself, but assuming you are from the USA:
Newegg has:
ANTEC Performance Plus Metallic Gray SOHO File Server Case (http://www.newegg.com/app/ViewProductDesc.asp?description=11-129-124&depa=1)
Color: Metallic Gray
Material: 1.0mm SECC
Drive Bays: 5.25'' x4,3.5''(External) x2, 3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2,IEEE1394 x1
Power Supply: N/A
Cooling System: 2 x 80mm Rear Fan
Motherboard Compatibility: up to Extended ATX
Dimensions: 20.6''x8.1''x18.6''
I suggest just looking around, going to local computer places etc...
