Help! He~lp me PLZ
A.todorov
First , forgive my english :D
these pics may help you
I had a problem with my HD so i tried using RecoveryConsole and i typed in this command
"FIXMBR"
but it doesnt work so i bought new HD and checked my old HD and my old HD is now FAT12
and has only 10 MB,, ive used many Recovery programs but They cant get all of my data back so i just want to know HOW CAN I DELETE THE 10MB MBR that i created from Fixmbr??
PLS ANYONE I WANT MY DATA BACK Y-Y
Yikes! If that was me, I'd backup all of my data and format both drives completely. GDisk works great in DOS and can clear any type of partition and MBR. Then you'll have fresh, empty drives to start over with.
"I'd backup all of my data and format both drives completely"
I would if i had 2 hdisk :[
DJNES , What is the command to delete MBR in GDisk PLEASE!! and Im sorry for another thread
I actually have a batch file that I run each time I need to clear the drive completely:
gdisk 1 /mbr
gdisk 1 /del /all
gdisk 1 /mbr
That will clear the MBR, then all partitions, and then the MBR once again. If you have 2 drives, you could repeat it by replace the 1 with a 2.
"That will clear the MBR, then all partitions"
Then all partition?!! No, Djnes I want to keep my data and store them to my new HD not clearing the partitions of my old HD and get my old HD works again i just want all of my data back from my old HD!! please How can i get rid of the 10MB !!
Okay, then run gdisk with no switches, and it will tell you what number partition is the 10 MB one. Then do a gdisk /? to find out the correct way to specify the partition in question. Once you delete the partition, boot back into windows.
