Have had problems with a year old laptop and the ram modules flaking out, use the computer heavily for work so took out the hard drive (80gb ata fujitsu ntfs) to put in an older laptop`(30gb ide fat 32).
Thought it might work but crashed windows xp on boot. bought an external enclosure for the drive as another method of getting to files but file system looks garbage, have now worked out that the computer is seeing at as a 30gb fat32 formatted hard drive.
Is this the reason why it cant read the files and the names of files and folders garbage? is there a way to change this back to ntfs without losing the all important data?
your help would be very much appreciated as im knackered without the work data.
thanks
thanks
