Help! - got back to school and comp dead - need advice
Ageanm
So I stored my rig over the summer and didn't use it at all for about 3 months. I just got back and have spent the past 2 days trying to get it to boot. I have figured out that the mobo is dead, most likely due to a leaking cap near the mofsets. Its weird though, with my video card in (a GForce 4 Ti 4400) it stops at one post code (26) and with a different vid card (an ATI Radeon 7000 - bought it to see if my vid was broken) I get a different post code (7f) which I can hit F1 to get past - but no video display at all. So my conclusion is that the mobo is dead (and there is a leaking cap near the mofsets).
So here is the challenge:
I will be leaving for a 6mo trip at the end of december, I need a rig capable of playing Civ 4 and GalCiv until then and I want to spend the least amount of money.
The current components I have:
Epox 8rda+ (this is busted)
Athlon 2100
Kingston HyperX 512MB CAS 2 DDR 3500
Gainward GForce 4 TI 4400
Antec Truepower 430W PS
(and a case, monitors etc)
Please help with suggestions - as you can see it has been ages since I built this rig and I havn't really kept up.
What do you guys (and gals) think I should buy/do!?
Thanks so much I really appreciate all your help!
$100 - Newegg special, Athlon 64 3400+ (Venice, 2.4GHz/512k L2) and your choice of 3 motherboards for yes... $100
X850 Pro - $120
512MB RAM - $30
